‎03-17-2023 03:25 PM - edited ‎03-17-2023 03:26 PM
Following the 10.4.2.4 update, many of our servers are showing Invalid namespace scanning errors for the Antivirus category, and say that no antivirus software is installed (before it showed Trellix ENS).
Solved! Go to Solution.
‎03-22-2023 12:09 PM
I worked with Lansweeper support, they can reproduce it internally. They logged it as LAN-14968 for a future fix.
‎03-22-2023 12:05 PM - edited ‎03-22-2023 12:05 PM
Same issue here :0
Waiting for a fix 🙂
‎03-22-2023 12:26 PM
Hello there!
Thanks for sharing the bug number!
‎03-17-2023 03:42 PM
Will do, thanks!
‎03-17-2023 03:28 PM
Hello there!
This has not been reported yet, so I would advise raising a support case: https://www.lansweeper.com/contact-support/
