‎07-05-2024 10:15 AM - edited ‎07-05-2024 10:46 AM
LS 11-series has strange bug - hundreds of repeating objects on Windows Server.
a lot of duplicates of Sentinel HASP Key in USB Devices with same deviceid (no idea what is root cause)
a lot of duplicates of disk partitions (300-600x) (Probably disk mounted on folder is reason of bug or hot-add backup)
‎07-15-2024 11:52 AM
do you know about this issue?
‎07-15-2024 12:46 PM
Hello there!
I can't say that I have seen this issue before, at least when you are speaking of hundreds of duplicates. I was going through our cases and the developer backlog, and I do not see any report on this.
We could potentially improve our method of obtaining the DeviceID. Currently, we query both Win32_USBControllerDevice and Win32_USBController and take just the last part. For example, if the DeviceID is USB\VID_0BDA&PID_5532\200901010001, we take just the last bit (200901010001), which in some cases leads to false duplicates if the last bit matches the DeviceID of another device. So, as an improvement, we should use the full DeviceID.
However, hundreds of duplicates do seem to be a lot!
‎07-16-2024 05:53 AM
And what about partitions?
‎07-16-2024 05:52 AM - edited ‎07-16-2024 05:52 AM
Did you run my queries for check your QA infra?
I think that before LS 10.5 there were constraints in SQL database which deny to save same info into the tables.
‎07-16-2024 02:23 PM
Hello there!
We do not see these issues in any of our environments currently. For the issue with partitions, this is also not a known issue.
‎07-10-2024 08:29 AM
Update queries to found duplicates
‎07-09-2024 08:35 AM
I think issues started in LS 10.5
‎07-09-2024 08:34 AM
Clean job for disk partitions:
delete from tblDiskPartition where tblDiskPartition.LastChanged
< (select max(intern.LastChanged) from tblDiskPartition as intern where intern.AssetID=tblDiskPartition.AssetID and intern.DiskIndex=tblDiskPartition.DiskIndex and intern.[Index]=tblDiskPartition.[Index])
‎07-09-2024 08:21 AM
Clean job for usb devices:
delete from tblUSBDevices where tblUSBDevices.LastChanged
< (select max(intern.LastChanged) from tblUSBDevices as intern where intern.AssetID=tblUSBDevices.AssetID and intern.DeviceID=tblUSBDevices.DeviceID and intern.name=tblUSBDevices.name)
