Options
‎11-16-2010 09:34 PM
I have finally got my servers built to install fresh install of 4.0.
My server is 2008 SP2 x64
my SQL is SQL 2008 Standard Edition 64-bit
the install seems fine. The only issue I get is that the domain account I use only has Admin rights on the server and on all PC's. It is not a Domain admin account.
When the instlal finishes it load the website and shows lots of erros, when I load the config tool every TAB gives me "Invalid object name 'TsysWaittime'" , "Invalid object name 'dbo.tblComputers'", I click OK to both and get into config but every tab I click I get a similar error.
Errorlog
11/16/2010 09:31:54: Invalid object name 'TsysWaittime'.
at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
at LansweeperService.mdlinit.Inittime(Int32 CFGcode, String CFGname, Boolean trackchanges, Int32 waitdays, SqlConnection& sqlcon)
Errorlog
Solved! Go to Solution.
Labels:
General Discussion
Options
‎11-18-2010 06:00 PM
Got it working. Thanks
I did a fresh install. is there a way to move my custom reports from 3.5 to the new 4.0?
Options
Options
‎11-19-2010 11:53 AM
You will need to copy the whole database and upgrade.
What was the exact problem with the installer?
Options
‎11-18-2010 01:11 PM
Please e-mail us about this problem.
Is the database on the same server as the service?
Options
‎11-17-2010 03:13 PM
File uploaded
Options
‎11-17-2010 09:46 AM
Could you please upload (or e-mail) the install.log file.
