Ingraham2
I have finally got my servers built to install fresh install of 4.0.
My server is 2008 SP2 x64
my SQL is SQL 2008 Standard Edition 64-bit
the install seems fine. The only issue I get is that the domain account I use only has Admin rights on the server and on all PC's. It is not a Domain admin account.
When the instlal finishes it load the website and shows lots of erros, when I load the config tool every TAB gives me "Invalid object name 'TsysWaittime'" , "Invalid object name 'dbo.tblComputers'", I click OK to both and get into config but every tab I click I get a similar error.
Errorlog
11/16/2010 09:31:54: Invalid object name 'TsysWaittime'.
at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
at LansweeperService.mdlinit.Inittime(Int32 CFGcode, String CFGname, Boolean trackchanges, Int32 waitdays, SqlConnection& sqlcon)
Ingraham2
Got it working. Thanks
I did a fresh install. is there a way to move my custom reports from 3.5 to the new 4.0?
Ingraham2
You will need to copy the whole database and upgrade.
What was the exact problem with the installer?
Please e-mail us about this problem.
Is the database on the same server as the service?
Ingraham2
File uploaded
Could you please upload (or e-mail) the install.log file.
