paucaronka
LAPS scanning credential Prerequisites are:
- AD LAPS is enabled on your domain.
- You're in possession of an account with admin rights for managing AD LAPS.
- The admin account must have the rights to run Remote PowerShell on the AD LAPS server.
When I test I get a "powershell connection to {DC} failed"
from the box lansweeper is installed I can PS: test-WSMan to the DC
As far as I can tell everything is set right and permissions are good. I can recover the correct LAPS password for that device using the LAPS GUI or powershell.
Any ideas?
How does the test tool operate?
does it construct a powershell command?
does it use a different port maybe blocked in the firewall?
paucaronka
support case for what? - does something need fixing?
I have exactly the same problem.
Manual testing with remote PowerShell to the DC works (both Test_WsMan and an Invoke-Command cfr this article https://support[.]servicenow[.]com/kb?id=kb_article_view&sysparm_article=KB0813330 )
But Lansweeper provides the same error to me. I've created a support case.
With description of workking process of the test tool and requiements for it.
Mister_Nobody
Honored Sweeper II
You have to create support case.
