‎10-03-2023 11:45 AM - edited ‎10-04-2023 07:07 AM
LS doen't show Videocard Model on Linux Assets
Display Video card No information found
But I see such info in lshw:
description: Desktop Computer
product: System Product Name (To Be Filled By O.E.M.)
vendor: System manufacturer
version: System Version
serial: System Serial Number
width: 4294967295 bits
capabilities: smbios-2.5 dmi-2.5 smp vsyscall32
configuration: boot=normal chassis=desktop family=To Be Filled By O.E.M. sku=To Be Filled By O.E.M. uuid=200D1125-4C48-DE11-9105-00248CE71867
*-core
description: Motherboard
product: P5KPL-AM SE
vendor: ASUSTeK Computer INC.
physical id: 0
version: X.0x
serial: MT7095K12300025
slot: To Be Filled By O.E.M.
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 0408
date: 04/10/2009
capacity: 960KiB
capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb ls120boot zipboot biosbootspecification
*-cpu
description: CPU
product: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
serial: To Be Filled By O.E.M.
slot: Socket 775
capacity: 3800MHz
width: 64 bits
clock: 200MHz
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl cpuid aperfmperf pni dtes64 monitor ds_cpl est tm2 ssse3 cx16 xtpr pdcm xsave lahf_lm pti dtherm cpufreq
*-cache:0
description: L1 cache
physical id: 5
slot: L1-Cache
capacity: 64KiB
capabilities: internal write-back data
configuration: level=1
*-cache:1
description: L2 cache
physical id: 6
slot: L2-Cache
capacity: 2MiB
capabilities: internal write-back instruction
configuration: level=2
*-memory
description: System Memory
physical id: 23
slot: System board or motherboard
*-bank:0
description: DIMM DDR2 Synchronous 800 MHz (1.2 ns)
product: PartNum0
vendor: Manufacturer0
physical id: 0
serial: SerNum0
slot: DIMM A1
width: 64 bits
clock: 800MHz (1.2ns)
*-bank:1
product: PartNum1
vendor: Manufacturer1
physical id: 1
serial: SerNum1
slot: DIMM B1
width: 64 bits
*-pci
description: Host bridge
product: 82G33/G31/P35/P31 Express DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 10
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: 82G33/G31/P35/P31 Express PCI Express Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 10
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:16 ioport:d000(size=4096) memory:fd000000-feafffff ioport:e6000000(size=167772160)
*-display
description: VGA compatible controller
product: GF108GL [Quadro 600]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nouveau latency=0
resources: irq:25 memory:fd000000-fdffffff memory:e8000000-efffffff memory:e6000000-e7ffffff ioport:dc00(size=128) memory:c0000-dffff
General Discussion
‎10-05-2023 05:17 AM
Oracle Enterprise Linux 7.9 kernel 4.14.35-2047.528.2.1.el7uek.x86_64
Stange things in log:
2023-10-04 16:54:22,412 [1] INFO LOGLINUX DEBUG Error happened: Command not found: bash: lshw: command not found
2023-10-04 16:54:22,413 [1] INFO LOGLINUX INFORMATIONAL Checking HAL availability.
2023-10-04 16:54:22,477 [1] INFO LOGLINUX WARNING HAL package is not found.
2023-10-04 16:54:22,479 [1] INFO LOGLINUX DEBUG Retrieving PCI Card info
2023-10-04 16:54:22,480 [1] INFO LOGLINUX DEBUG Executing GetPciCardsWithLspciVm with sudo
2023-10-04 16:54:22,570 [1] INFO LOGLINUX DEBUG Command not found: sudo: lspci: command not found
2023-10-04 16:54:22,572 [1] INFO LOGLINUX DEBUG Executing GetPciCardsWithLspciVm without sudo
2023-10-04 16:54:22,635 [1] INFO LOGLINUX DEBUG Command not found: bash: lspci: command not found
2023-10-04 16:54:22,637 [1] INFO LOGLINUX DEBUG Executing GetPciCardsWithPciconfLv
2023-10-04 16:54:22,692 [1] INFO LOGLINUX DEBUG Command failed: bash: pciconf: command not found
2023-10-04 16:54:22,697 [1] INFO LOGLINUX DEBUG Executing GetPciCardsWithLspciVm without sudo
2023-10-04 16:54:22,800 [1] INFO LOGLINUX DEBUG lspci -vm output: Device: 00:00.0
Class: Host bridge
Vendor: Intel Corporation
Device: 440BX/ZX/DX - 82443BX/ZX/DX Host bridge
SVendor: VMware
SDevice: Virtual Machine Chipset
Rev: 01
Device: 00:01.0
Class: PCI bridge
Device: 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge
Rev: 01
Device: 00:07.0
Class: ISA bridge
Device: 82371AB/EB/MB PIIX4 ISA
SVendor: VMware
Rev: 08
Device: 00:07.1
Class: IDE interface
Device: 82371AB/EB/MB PIIX4 IDE
SVendor: VMware
Rev: 01
ProgIf: 8a
Device: 00:07.3
Class: Bridge
Device: 82371AB/EB/MB PIIX4 ACPI
SVendor: VMware
Rev: 08
Device: 00:07.7
Class: System peripheral
Vendor: VMware
Device: Virtual Machine Communication Interface
SVendor: VMware
SDevice: Virtual Machine Communication Interface
Rev: 10
Device: 00:0f.0
Class: VGA compatible controller
Vendor: VMware
Device: SVGA II Adapter
SVendor: VMware
SDevice: SVGA II Adapter
All tools are present but no info about videocard
‎10-05-2023 08:40 AM
Hello there!
We do see that certain commands are not run with sudo rights, if running these commands fails due to a lack of sudo rights, some hardware information may not be scanned. So this is a potential explanation of the issue.
A list of commands can be found here: https://community.lansweeper.com/t5/requirements/scanning-commands-run-on-linux-computers/ta-p/64579
‎12-14-2023 04:40 AM
Could you explain concrete command to collect videocard info which I can run to check issue?
‎12-15-2023 11:54 AM
Hello there!
These are the commands that we use:
lspci -vm
pciconf -lv
‎12-15-2023 12:25 PM
OEL 7.9 , lspci -vm works, LS doesn't collect info
Device: 00:0f.0
Vendor: VMware
SVendor: VMware
‎12-15-2023 02:31 PM
Hello there!
It's not entirely clear what the issue could be, and we are not really getting any other reports regarding this particular issue. So it will be hard to troubleshoot this without raising a support case.
‎12-14-2023 12:30 PM
Hello there!
I don't have access to the scanning code, but I will check with our product team and see if I can get this command for you.
‎10-04-2023 06:15 AM
LS doesn't call lshw for graphic card inventory - only for sound(WTF?)
2023-10-03 14:47:02,031 [1] INFO LOGLINUX DEBUG Executing GetSoundCardsWithLshw
2023-10-03 14:47:02,729 [1] INFO LOGLINUX DEBUG lshw multimedia output: WARNING: you should run this program as super-user.
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
<?xml version="1.0" standalone="yes" ?>
<!-- generated by lshw-development -->
<!-- GCC 9.1.0 -->
<!-- Linux 5.15.133TS #1 SMP PREEMPT Fri Sep 29 10:58:58 UTC 2023 x86_64 -->
<!-- GNU libc 2 (glibc 2.32) -->
<!-- WARNING: not running as root -->
<list>
<node id="multimedia" claimed="true" class="multimedia" handle="PCI:0000:01:00.1">
<description>Audio device</description>
<product>GF108 High Definition Audio Controller</product>
<vendor>NVIDIA Corporation</vendor>
<physid>0.1</physid>
<businfo>pci@0000:01:00.1</businfo>
<version>a1</version>
<width units="bits">32</width>
<clock units="Hz">33000000</clock>
<configuration>
<setting id="driver" value="snd_hda_intel" />
<setting id="latency" value="0" />
</configuration>
<capabilities>
<capability id="bus_master" >bus mastering</capability>
<capability id="cap_list" >PCI capabilities listing</capability>
</capabilities>
<resources>
<resource type="irq" value="17" />
<resource type="memory" value="feafc000-feafffff" />
</resources>
</node>
<node id="multimedia" claimed="true" class="multimedia" handle="PCI:0000:00:1b.0">
<product>NM10/ICH7 Family High Definition Audio Controller</product>
<vendor>Intel Corporation</vendor>
<physid>1b</physid>
<businfo>pci@0000:00:1b.0</businfo>
<version>01</version>
<width units="bits">64</width>
<configuration>
</configuration>
<capabilities>
</capabilities>
<resources>
<resource type="irq" value="24" />
<resource type="memory" value="fcffc000-fcffffff" />
</resources>
</node>
</list>
2023-10-03 14:47:02,729 [1] INFO LOGLINUX DEBUG Executing ParseSoundCardsFromLshw
‎10-03-2023 11:52 AM
Scan Test Tool has same issue
