nemBela
Is it possible to add manually multiple network interfaces to an asset that was added through the "New Asset" form?
george29
do you have an example of how this would be manually added to the database?
also how would it be possible with lspush if it wasn't a windows device?
is there a way to hand make a file similar to how lspush does?
Unfortunately not through the web console. You can add the data, but you would need to manually insert it into the database.
Lansweeper is really designed to scan the information. If you only need it in Lansweeper for keeping records, the best thing to do would be to do a quick scan with the old scanning agent LsPush and import the file into lansweeper.
