David_Elliott
Lansweeper scans copiers/MFDs and adds them as printer asset types by default. I created a new asset type called Copier-MFD to segregate my leased copiers-MFDs from my regular networked printers. However, when I change the asset type from Printer to Copier-MFD, I lose all the toner/fuser/drum level indicators. See screen shots of same device.
How can I change the Copier-MFD asset to display the same info as the Printer type?
This is not currently possible. Printer specific information (e.g. toner information) will only be displayed if the asset type is set to "printer". You could use asset groups or a custom field to categorize the printers instead.
