DB-Karolis
I have the same problem that a previous user here had:
https://community.lansweeper.com/t5/general-discussions/cloud-discovery-actions-identity-and-access-...
I set up everything correctly it seems. On Scan time - it shows its trying to scan for Entra ID, but after hour or so nothing comes from it - no users, nothing.
FrankSc
Dear,
Do you mind reaching out to Support for this, and creating a case? Our team can look at your scanning actions based on your SiteID and verify if something is missing in the setup or not.
FrankSc
Dear,
