‎02-10-2010 02:56 PM
i cant seam to get the report "No F-Secure installed " to work, it shows 0 and i know that that is wrong,
i can se that the report i looking for = Like %fssm32%
a sweep of my system finds no fssm32 so why is it showing that alle systems are AV'ed
(dir /s *fssm32*)
any ideas
Solved! Go to Solution.
General Discussion
‎02-11-2010 01:46 PM
Select Top 1000000 dbo.tblComputers.Computername As Computer,
dbo.tblOperatingsystem.Description, dbo.tblFileVersions.Lastchanged
From dbo.tblComputers Inner Join
dbo.tblComputersystem On dbo.tblComputers.Computername =
dbo.tblComputersystem.Computername Left Outer Join
dbo.tblOperatingsystem On dbo.tblComputers.Computername =
dbo.tblOperatingsystem.Computername Left Outer Join
dbo.tblFileVersions On dbo.tblComputers.Computername =
dbo.tblFileVersions.Computername
Where dbo.tblFileVersions.FilePathfull Like '%fsav.exe%' And
dbo.tblFileVersions.Found = 0
Order By dbo.tblFileVersions.Lastchanged Desc
‎02-11-2010 10:13 AM
Lansweeper wrote:
In the configuration tool you can add "scanned files"
All computers are scanned if this file exists and what the version number is.
You can then use this information to build custom reports.
ahhhh!
so i add this to the "scanned files" tab:
%programfiles%\F-Secure\Anti-Virus\fsav.exe
changed the report to '%fsav%'
and then restart the lansweeper service to get a new scan,
waited to all the scannes was done, then the web service.
no output?
‎02-11-2010 09:40 AM
If you don't scan this file or don't use f-secure you can safely remove the report.
‎02-11-2010 09:42 AM
Lansweeper wrote:
This is an example report that uses the scanned file '%fssm32%'
eh then i misunderstod the overall setup, sorry
how can i get started scanning for f-secure then .
‎02-11-2010 09:28 AM
‎02-11-2010 09:36 AM
Lansweeper wrote:
Could you give me the sql definition of the report please.
it is the standart report
Select Top 100 Percent dbo.tblComputers.Computername As Computer, dbo.tblOperatingsystem.Description, dbo.web30repdomainswithfsecure2.Domain, dbo.tblFileVersions.Lastchanged From dbo.tblComputers Inner Join dbo.tblComputersystem On dbo.tblComputers.Computername = dbo.tblComputersystem.Computername Inner Join dbo.web30repdomainswithfsecure2 On dbo.tblComputers.Domain = dbo.web30repdomainswithfsecure2.Domain Left Outer Join dbo.tblOperatingsystem On dbo.tblComputers.Computername = dbo.tblOperatingsystem.Computername Left Outer Join dbo.tblFileVersions On dbo.tblComputers.Computername = dbo.tblFileVersions.Computername Collate Latin1_General_CI_AS Where dbo.tblFileVersions.FilePathfull Like '%fssm32%' And dbo.tblFileVersions.Found = 0 And dbo.tblComputersystem.Domainrole = '1' Order By dbo.web30repdomainswithfsecure2.Domain, dbo.tblFileVersions.Lastchanged Desc
‎02-10-2010 05:05 PM
‎02-11-2010 08:53 AM
Lansweeper wrote:
Do you scan for this file using the file scanning?
not sure what you saying, the report is showing all servers and workstations have fsecure but
if i take a machine that i know is in the list and tjek for installed software there is none, if i on the machine go to a cmd and search for fsecure there is none, never has been :-d
