S_Kunimuench
Hello everyone,
I'm currently still on version 12.3.2.5. With this version, I set up a second scan server, which is working very well.
However, I’m unable to update to a newer version, and I'm not sure if this issue started after setting up the second scan server.
Every time I try to update, it proceeds up to the start of the update, and then a browser window opens with the unhelpful message:
"An Installation Error Occurred. It looks like something went wrong."
Does anyone have an idea what might be causing this? These are the last lines in the setup log
2025-05-12 07:33:53.256   Extracting temporary file: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp\WebpiCmd-x64.exe
2025-05-12 07:33:53.256   Extracting temporary file: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp\WebpiCmd-x64.exe.config
2025-05-12 07:33:53.271   Extracting temporary file: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp\Microsoft.Web.PlatformInstaller.dll
2025-05-12 07:33:53.319   .Net Framework 4.8 already installed (4.8.04161).
2025-05-12 07:33:53.319   Extracting temporary file: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp\VC_redist.x64.exe
2025-05-12 07:33:53.319   CurStepChanged raised an exception (fatal).
2025-05-12 07:33:53.319   Deinitializing Setup.
2025-05-12 07:33:53.319   Lansweeper Setup Aborted! Failed Actions: Error:  The process cannot access the file because it is being used by another process.! Failed:  The process cannot access the file because it is being used by another process.! Errorcode:
2025-05-12 07:33:56.422   Failed to remove temporary directory: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp
2025-05-12 07:33:56.434   Log closed.
I’ve already stopped and disabled all Lansweeper services and rebooted the server, but the same behavior persists.
I’m using Lansweeper with IIS (not Express) and a separate MS SQL Server.
Thanks and best regards,
Sascha
S_Kunimuench
I wrote a mail to support@lansweeper.com and get this answer
Thank you for contacting Lansweeper Support.
This error message:
Is usually related to the antivirus or antimalware software installed on your computer. We've found that some AV/AM software, such as Cisco's, might lock files needed by the installer, like the C++ installers. We have created a bug about it, LAN-17510. Once it is solved, it will appear in our changelog: https://www.lansweeper.com/changelog/
Works for me.
10 REPLIES 10
S_Kunimuench
Hello Frank,
I've already done that. I stopped and disabled all services to ensure they wouldn't restart after a reboot. Unfortunately, the same error still occurs.
This happens on both servers — the main server and the scan server.
Best regards,
Sascha
