05-12-2025 07:59 AM
Hello everyone,
I'm currently still on version 12.3.2.5. With this version, I set up a second scan server, which is working very well.
However, I’m unable to update to a newer version, and I'm not sure if this issue started after setting up the second scan server.
Every time I try to update, it proceeds up to the start of the update, and then a browser window opens with the unhelpful message:
"An Installation Error Occurred. It looks like something went wrong."
Does anyone have an idea what might be causing this? These are the last lines in the setup log
2025-05-12 07:33:53.256 Extracting temporary file: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp\WebpiCmd-x64.exe
2025-05-12 07:33:53.256 Extracting temporary file: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp\WebpiCmd-x64.exe.config
2025-05-12 07:33:53.271 Extracting temporary file: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp\Microsoft.Web.PlatformInstaller.dll
2025-05-12 07:33:53.319 .Net Framework 4.8 already installed (4.8.04161).
2025-05-12 07:33:53.319 Extracting temporary file: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp\VC_redist.x64.exe
2025-05-12 07:33:53.319 CurStepChanged raised an exception (fatal).
2025-05-12 07:33:53.319 Deinitializing Setup.
2025-05-12 07:33:53.319 Lansweeper Setup Aborted! Failed Actions: Error: The process cannot access the file because it is being used by another process.! Failed: The process cannot access the file because it is being used by another process.! Errorcode:
2025-05-12 07:33:56.422 Failed to remove temporary directory: C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp
2025-05-12 07:33:56.434 Log closed.
I’ve already stopped and disabled all Lansweeper services and rebooted the server, but the same behavior persists.
I’m using Lansweeper with IIS (not Express) and a separate MS SQL Server.
Thanks and best regards,
Sascha
Solved! Go to Solution.
Question
3 weeks ago
I wrote a mail to support@lansweeper.com and get this answer
Thank you for contacting Lansweeper Support.
This error message:
Is usually related to the antivirus or antimalware software installed on your computer. We've found that some AV/AM software, such as Cisco's, might lock files needed by the installer, like the C++ installers. We have created a bug about it, LAN-17510. Once it is solved, it will appear in our changelog: https://www.lansweeper.com/changelog/
Works for me.
3 weeks ago
I'm still waiting for a solution here. Either how I can get the update installed, or how I can open a ticket. Because neither is working at the moment. It would be really nice if someone from support could finally get back to me.
Bye, Sascha
4 weeks ago
Hello team,
Same issue on our end as well. Stuck on 12.3.3.0 version for a long time now, since then whenever I have attempted to upgrade to the latest version keeps failing with the below message.
Lansweeper Tech Support, please for you support to identify the root cause and sort it out asap.
3 weeks ago
This error message:
Works for me.
Tuesday
S_Kunimuench hi,
Super. Issue resolved. You are right. The AV was the root cause. Many thanks!
05-13-2025 08:53 AM
Can someone help me? I’m unable to create support cases.
05-12-2025 01:30 PM
Dear,
Based on the error, could you please also check if there are no read/write issues on C:\Users\xxxxx\AppData\Local\Temp\is-R3TN2.tmp?
If the issue remains, please create a Support Case.
a month ago
Can you please help me so that I can open a support case? As soon as I click on 'Create Case', nothing happens.
05-12-2025 02:34 PM
I also already deleted the temp folder and saw it being recreated. I don’t think that’s the cause.
When I click on “Create Case,” the page doesn’t load for me. What could be the reason for that?
05-12-2025 01:07 PM
Dear,
Can you check if there is still a tool open? Like ConfigEditor.exe, or DatabaseMaintenance.exe?
The error typically indicates that an exe cannot be replaced, because it is still running or open.
Additionally, check to stop all Lansweeper-related services.
