cameronmckendry
Is it possible to install a Lansweeper server on a server in a datacenter then installer the LsAgent on PCs at a different location. The networks would not be linked by a VPN
RobertBasil
Relay server connection
If the computers you're scanning do not have a direct connection to your Lansweeper installation, scanned LsAgent data can be sent to our relay server in the cloud. For this, you must enable relay access in your Lansweeper installation. Scanned LsAgent data is sent securely over HTTPS (TLS 1.2) to the relay server in Microsoft Azure, where it is encrypted as well. Your Lansweeper scanning server can retrieve the scanned data from the relay server, after which it is deleted from the relay. In order to use the relay server, make sure outbound traffic is allowed on your Lansweeper scanning server. Specifically, the scanning server must be able to make an outbound connection to port 443 of relay.lansweeper.com, the cloud relay server.
