‎10-02-2015 06:37 PM
Solved! Go to Solution.
‎10-05-2015 01:09 PM
crashff wrote:
I removed a remote monitoring agent from all of our workstations using the software's own removal tool (LabTech, using Labtech's Agent Uninstaller) The program no longer shows in the Windows 7 Programs listing, and no longer has a folder on the hard drive either, yet Lansweeper is /still/ reporting the software as being installed on some workstations, and when I run the Remote Uninstaller utility, it scans the remote workstation and still has LabtechAD listed as an installed program.
I ran psexec msie to see if it was still there, and I get a return code saying that it only works for software that is installed. How can lansweeper report the software is still there, when the source it reads says the software isn't?
crashff wrote:
I also have issues where attempting to use the Software uninstaller does not silently uninstall anything. it instead pops up a message box repeatedly on the destination computer that interrupts the person working and will not go away unless I task kill it - the software I was attempting to uninstall never gets removed.
‎10-14-2015 10:43 AM
‎10-12-2015 11:23 PM
‎10-09-2015 12:04 PM
‎10-06-2015 08:14 PM
