cheche
Hi, when I modify a report in ReportBuilder, if I add a new table screen goes to blank.See attachments.
Can anybody help me?
cheche
SOLVED! The problema was around IIS configuration. Aplication pool was recycling continously because a wrong memory configuration. Fixing memory parameter solves the problem.
cheche
Could you:
  • Double-check that you are using a supported browser: Internet Explorer 8 or higher, Firefox or Chrome.
  • Ensure that third-party browser plugins are not to blame. I recommend disabling all plugins and restarting your browser as a test.
  • If the issue persists, try reinstalling your web console as explained here.
cheche
I get the impression that the problem arises only when I add a table that has no relation to existing tables in query.
My SQL Server is 2014.
My Windows Server is 2008R2.
