erik_marschang
We have several laptops that utilize Sabrent Universal USB 3.0 docking stations. Is there way to search for who all might be using these docks?
JacobH
Sweet - glad that worked for you
JacobH
you should be able to use the built-in report Windows: USB connected devices
then you can filter the report by 'USBDeviceName'
Example for mine is HP USB-C Universal Dock
if you need help figuring out the name for the dock, you can go to one machine in lansweeper, config > hardware > usb devices and look for the appropriate name to then filter your report.
hope that helps
hope that helps
This worked perfectly! Thank you for the quick reply!
