made_suardana
hi all,
I am using Lanssweeper. recently I was having an internal audit and one particular point they highlighted is "Lansweeper to be updated to using https".
Can I know this actually means?
Thank you
You can enable HTTPS for your Lansweeper web console in Configuration\Website Settings.
Website settings
However, you will have to configure your web server first. To set up SSL for IIS Express you can follow our instructions here: https://www.lansweeper.com/kb/54/How-to-configure-SSL-in-IIS-Express.html
If you are using the standard IIS, you can follow Microsoft's instructions here: https://docs.microsoft.com/en-us/iis/manage/configuring-security/how-to-set-up-ssl-on-iis#iis-manager
ptondele
made.suardana@comohotels.com wrote:
hi all,
Thank you
this is a security measurement to ensure data is encrypted.
activation needs to be done on you IIS application server
