kchilton27
We just purchased Lansweeper and would like to leverage it to uninstall Microsoft Office using the Easy Fix Tool (o15-ctrremove.diagcab) Then after that has ran on the remote computer, we would like to install our Office 365 ProPlus 32bit installer (for office 2016) so that we are using our E3 licensing that we have purchased. Can anyone advise me how to implement what we want to do please? I’ve been messing around in Deployment, but can’t figure out the right package steps to do to make this happen.
Argon0
Thanks CharlesX,
I created a package for installing O365 Click to run before I came across the one in the forums...
Its just uninstalling Office 2010 I need to work out - think I have found how to do it, just need to put some time into it!
Andy
The o15-ctrremove.diagcab will have to be called on by a script in the deployment module. For installing Office365 I would recommend you do some research. I did a quick online search and was able to find some sources which will be useful.
The first is on our own forums. User keys_it shared a deployment packaged for Office 365: https://m.lansweeper.com/forum/yaf_postst14059_Office-365-ProPlus-Installer.aspx#post48805
He also helped in this topic to deploy the "Click to run" Microsoft technology: https://www.lansweeper.com/Forum/yaf_postst10498_Deploy-click-to-run-technologies.aspx#post39410
The second one is a more general but might also help: https://marckean.com/2013/07/01/fully-automate-the-installation-of-office-365/
Hope this helps you.
Argon0
I'd like to know this too - I created an installer for Office365 Apps (bar Teams and OneDrive - which install into the user spaec :(). but its the uninstall of Office 2010 I'm looking to do.
Argon0
