RayPamps23
What will happen when my SQL LocalDB becomes full? Will Lansweeper still work when it reaches the 10GB limit?
Your database has nearly reached your database server's built-in size limit. SQL LocalDB and SQL Express databases are limited in size by Microsoft. Information on resolving this issue can be found in this knowledge base article.
FrankSc
If your SQL LocalDB will become full, your Lansweeper installation will stop working. The scanning service will not be able to add data to the database, and could possibly become in a sort of locked status. Both SQL LocalDB and SQL Express are limited to 10GB.
To limit the size you could also follow the steps in this KB article regularly:
https://www.lansweeper.com/knowledgebase/clearing-tables-to-free-up-space-and-improve-performance/
If you really bump into the limit frequently, we recommend moving to another SQL edition that does not have the limit.
