rom
PleasePleasePlease add more custom fields for assets! Crank it up to 50!!
I use the custom fields to integrate/insert data from other systems (in addition to manual fields) - and I'm running out!!
Examples:
Veeam backup status (powershell) - > custom10 Veeam last backup (powershell) > custom11
Veeam replication status > custom12 Veeam last replication > custom13
Tintri replication status (powershell) > custom14
Tintri replication schedule (powershell) > custom15
Tintri replication duration > custom16
PRTG Monitoring status (API to CSV) > custom17
you get the idea - the more columns we have, the more info we can store! Currently, I have to sacrifice a column to make a new one.
-Rom
DonMario73
Hi Lansweeper, can yo tell us if additional custom fields will be added in future versions?
Regards
rmckenzie
