‎11-04-2014 01:23 AM
Solved! Go to Solution.
‎09-12-2018 04:53 PM
‎11-10-2017 09:23 PM
‎11-17-2017 10:56 PM
RichFinch wrote:
It looks like you can add OID's under Configuration -> Asset Mapping, Scroll to bottom. Im having some issues scanning a device, but it seems the feature is there
‎10-13-2017 11:29 PM
‎10-13-2017 09:09 PM
‎08-15-2017 09:36 AM
‎08-14-2017 07:16 PM
‎08-14-2017 06:58 PM
‎10-14-2017 01:52 AM
joe_user wrote:
Must have MIB import to properly inventory our Aerohives.
Are wishlist items weighted by how far-reaching the impact would be? I understand that weight might be given to the number of customers requesting a feature divided by some factor of difficulty to develop. However, without MIB import, significant portions of infrastructure aren't visible. Perhaps a multiplier should be impact to community, and, in this case, it would seem to be a significant potential marketing angle: "single pane of glass for infrastructure visibility" and all that.
Just think, with MIB import support, if you also got together with Paessler for an integration #wakesUpFromDream
