sseal
When multiple credentials are specified for ssh if any one fails the device will show in the "All Devices with Errors" report with a ssh credentials failed error.
Could we make it so that if at least one of the three optional credential sets work that the device does not generate an error?
BTW, great job on the multiple credentials!!
7 REPLIES 7
sseal
Ok, thank you for the reply. Heres to hoping!!
sseal
lots of network devices use only a password to connect with a blank username. Sometime over http but usually over telnet/ssh. right now we cannot connect and scan these devices because we are required to specifiy a username.
Telnet scanning is not implemented (and will probably not be implemented in the future)
SSH scanning with an empty username might be implemented in the future but for now it's not possible because the third party vendor's library does not support it.
sseal
we also need the ability to specifiy a password only, at least once you get telnet working
What exactly do you mean by this?
sseal
Thanks.
OK
