‎03-01-2024 09:31 AM
I'm using Lansweeper v. 11.1.6.0, scanning a vSphere 8 environment. I have done all the steps in -->
Troubleshoot vCenter scanning issues - Lansweeper Community
However the Hosts and guests are not showing up in the vCenter inventory, only the Datacenter and the Datastores are visible.
What am I doing wrong? If I use the Lansweeper Devicetester I can see everything listed from the vCenter - it is just not showing up in the Web Interface
//Mathias
Solved! Go to Solution.
‎03-21-2024 07:29 AM
FYI, found the solution. Support pointed me in the right direction.
In my case there was a folder on the top of my vCenter inventory, above the vCenter itself. I removed that folder and now everything gets scanned as it should 🙂
‎03-01-2024 10:15 AM
‎03-01-2024 10:25 AM
Thanks, I will try to do that, however since the license was purchased from a different email I can't register a support case and I get no response from sales:
"We are unable to match the email address you are currently logged in with a customer account in our systems. Please make sure that you are logged in with your business email address or contact our sales team via this link. "
‎03-01-2024 01:31 PM
Try to request trial on new business e-mail and create case
‎03-01-2024 10:14 AM - edited ‎03-01-2024 10:14 AM
Run tool "c:\Program Files (x86)\Lansweeper\Service\Lansweeper.TestTools.App.exe"
Select vcenter
Set IP and creds
View log named as Lansweeper.TestTools.Errorlog.txt
‎08-19-2024 07:57 PM
The tool does not produce a log file. Is there something I am missing to generate one?
‎03-01-2024 12:32 PM
Thanks for linking to this test tool - wasn't aware of that. However, throws error when testing vCenter:
Error occurred
Self referencing loop detected for property 'Task' with type 'System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1+AsyncStateMachineBox`1[Lansweeper.Service.Domain.vCenter.VCenter,Lansweeper.Service.SA.Vmware.VCenterClient+]'. Path 'StateMachine.'
‎03-15-2024 03:13 AM
Try new version
‎03-19-2024 01:10 PM
Thanks, I tried upgrading to the latest version. Still the same issue unfortunately.
I have registered a support case now
‎03-19-2024 02:55 PM
From support -->
"The error has already been reported to our Development Team, and a bug report has already been created, LAN-12409.
Unfortunately, there is currently no work-around for this."
