MB74
I'm using Lansweeper v. 11.1.6.0, scanning a vSphere 8 environment. I have done all the steps in -->
Troubleshoot vCenter scanning issues - Lansweeper Community
However the Hosts and guests are not showing up in the vCenter inventory, only the Datacenter and the Datastores are visible.
What am I doing wrong? If I use the Lansweeper Devicetester I can see everything listed from the vCenter - it is just not showing up in the Web Interface
//Mathias
MB74
FYI, found the solution. Support pointed me in the right direction.
In my case there was a folder on the top of my vCenter inventory, above the vCenter itself. I removed that folder and now everything gets scanned as it should 🙂
13 REPLIES 13
MB74
dlafleur
when you say "there was a folder on the top of my vCenter inventory, above the vCenter itself", where did you see that at?  Do you have a screenshot you can share?
shamburg
What do you mean "on top of my vcenter inventory"? Can you post a screenshot or describe in more detail?
DonMario73
Greetings, I am having the same issue.  Can you share more details about the workaround?
Regards
Product Discussions
