sbukovic526
Please add the ability to rescan a defined IP range at will rather than being required to restart the server service and ping flood all subnets and device nodes on the network.
DGoodwin
I'd like to second the request. Would be nice to scan just one of the ranges on demand. Maybe implement it into the IP Location Overview section?
We have added this feature request to our customer wish list, but this may not be implemented. You can hit the Disable All IP Ranges button to disable all of your IP ranges and re-enable just the ranges you need.
sbukovic526
To clarify, It would be better if you had a button per ranged added that you could click for rescan rather than having to deselect all a and then selecting the defined network range to scan an performing a rescan. Currently too many steps to perform the functionality. Would help access troubleshooting due to security and firewall restrictions that are being resolved.
Product Discussions
