You've got multiple subnets in your network and created an IP Range scanning target for each one.
Excited to witness Lansweeper's capabilities, you've added all the targets. The results are coming in, and everything seems to function correctly.
You continue to add other scanning targets to discover the full potential of Lansweeper, but you're noticing a slowdown or clog in the scanning process.
What happened?
By default, every day at 12 pm (local scanning server time), all IP Range scanning targets are scheduled to be scanned automatically.
If you have several of these targets, Lansweeper's scanning service will be busy for a significant amount of time every day at noon. When setting up IP Scanning targets, it's easy to overlook the scheduling options for each target you create.
Now what?
To reduce the likelihood of a heavy load, it is recommended to reschedule the IP Range scanning targets to start at a different time of day. However, if you have numerous IP Range scanning targets set up in Lansweeper, rescheduling them individually can be a tedious task. Fortunately, you can use a script to automate the process and let the computer do the heavy lifting.
The script below will randomize each IP Range scanning target:
Before running any database script, back up your database first.
DECLARE @IPrangeID int
DECLARE MY_CURSOR CURSOR
  LOCAL STATIC READ_ONLY FORWARD_ONLY
FOR
SELECT DISTINCT IprangeID
FROM tsysIPScanRanges
OPEN MY_CURSOR
FETCH NEXT FROM MY_CURSOR INTO @IPrangeID
WHILE @@FETCH_STATUS = 0
BEGIN
	update tsysipscanranges set
	Day1time = CONVERT(DATETIME, RAND())
	where iprangeID = @IPrangeID
    PRINT @IPrangeID
END
CLOSE MY_CURSOR
DEALLOCATE MY_CURSOR
	Day2time = Day1time,
	Day3time = Day1time,
	Day4time = Day1time,
	Day5time = Day1time,
	Day6time = Day1time,
	Day7time = Day1time
update tsysupdate set IpScanRanges = getdate()
Your IP Range scanning targets will now be scheduled to run throughout the day for better organization and efficiency.
3 Comments
rinks
Where do we run scripts from? Within Lansweeper? From the Lansweeper server device? Any device with LsAgent installed through PowerShell?
Mister_Nobody
Honored Sweeper III
You can run script in SQL Management Studio on lansweeperdb.
ErikT
@rinks
If you do not have SQL Management Studio installed, you can execute this script with the Lansweeper SQL Maintenance tool.
This is located on your scanning server.
Program Files (x86)\Lansweeper\Tools\DatabaseMaintenance.exe
  • Open the tool
  • Select the Script Execution tab
  • Copy and paste the code
  • Click Execute
