ErikT
You've set up everything to run automated warranty checks with Lansweeper. Unfortunately, you don't see any warranty information for your HPE or HP Inc. devices.
What happened?
HP Enterprise and HP Inc. warranty scanning are currently down due to changes HP made to its data back-end.
We've contacted HP, and they are working on a process to provide bulk warranty data through a publicly available API.
Once this API is available, Lansweeper will restore HP warranty scanning functionality. Thank you for your patience and understanding while we wait for this issue to be resolved.
Not seeing warranty information on non-HP devices?
Run through the warranty scanning articleAutomated warranty check for Dell, Fujitsu, HP, IBM, Lenovo and Toshiba, double-checking everything is set up correctly.
Did you have a similar issue and a different solution? Share your work in the comments below and help your fellow IT Heroes!
7 Comments
dcrashdummy64
Any update on this from either LanSweeper or HP when it will be resolved?
erling_AK
ErikT
Hi there,
The update from our product team can be found here:
Update: HP and IBM warranty scanning - Lansweeper Community - 71066
Chrille
It been a year to resolve the API what is happening?
This is one of the most important data for us to manage the lifespan and exchange rate of our assets and calculate EOL and budgeting, and also one of the main reasons we started to use Lansweeper.
Obi_1_Cinobi
Hello there!
The HP Warranty API is a RESTful programmatic interface that provides warranty information about HP devices. It is designed for HP's enterprise customers to check the warranty status of their fleet of HP devices. However, the HP Warranty API is currently not available for IT service companies and third-party ISVs that need to check warranty information for their customers' devices. As a result, at this time, Lansweeper is unable to retrieve HP warranty information.
zamudiom
I'm guessing this still has not been resolved?
Obi_1_Cinobi
Hello there!
That is correct. The HP Warranty API is not available for IT service companies and third-party ISVs that need to check warranty information for their customers' devices.
