Showing results forĀ
Did you mean:Ā
Tony_Cooke
Hi.
I was wondering is someone had created a report to check all PCs in an organisation to see if they meet the requirements outlined in the link below.
IntelĀ® Management Engine Critical Firmware Update
IntelĀ® Management Engine Critical Firmware Update (Intel SA-00086)
To check all machines manually may take a while so before I look at creating a report I just thought I'd check here to see if someone already had.
Thanks in advance.
All the best,
Tony
14 REPLIES 14
Estimados,
Tengo problemas en el paso del VBS, sale:
Result: Package timeout reached. Stopping deployment executable: Successful. Timeout: (300sec).
Por favor su apoyo.
Saludos
Tony_Cooke
Thanks Charles.X.
I'll check it out and get back to you.
All the best,
Tony
Just a quick update. We created a deployment package and report combination which you can use to check your assets for this vulnerability. You can find all the details here: https://www.lansweeper.com/forum/yaf_postst15642_Discover-devices-vulnerable-to-Intel-SA-00086.aspx#post52767
Luis_Miguel_Gue
Estimados,
Se agradece su apoyo con este inconveniente, ya que nos seria de mucha ayuda tener un reporte con esta mención.
Unfortunately, I don't have a report which gives a list of all asset with possible vulnerabilities related to the recent Intel firmware vulnerabilities.
I did however notice that Intel released a detection tool which you can use. In theory it would also be possible to use this tool with Lansweeper. According to Intel's description one version of the tool is a console executable that saves the discovery information to the Windows registry and/or to an XML file. If this information is correct you could use the deployment module to deploy the executable to your assets and save the information in a registry key which can be scanned using custom registry scanning. Once you have scanned the value out of the registry key you can use a report to get a list of assets with a specific value in that registry key.
Reports & Analytics
