Options
‎05-20-2010 01:39 AM
I built our Lansweeper 4 server with SQL Express 2008 as I used the 2005 version with a version 3 server and had no problems.
Now initially despite saying only look in this ou, Lansweeper found a bunch of computer's it shouldnt have, but I deleted the data via the Lansweeper Configuration utility.
I've got approx 1000 computers, but the SQL is reporting my database is full. I've checked and from what I can quickly tell there is only the data that there should be.
I was wondering if A)could tell me if SQL Expres won't just work B)Help clean out the db.
I tried shrinking the database but it's currently sitting at 0% free and won't actually shrink.
Thanks.
Thanks.
Labels:
Options
‎05-20-2010 01:33 PM
SQL express maximum size is 4GB
The problem is most likely the event logs which take a lot of space.
You can clear table "tblntlogevent" before shrinking.
sql code:
truncate table tblntlogevent
sql code:
