mmapplebeck
Hi there, I just installed LanSweeper last night, great proggie! Got the server and clients running, only problem left is the webconsole, I have everything setup and can goto the site, but I am getting errors with it, wonder if anybody can help. I'm sure it is a simple configuration error that meeds a simple change to work and I'll kick myself afterwards, below is the error and my web.config file. - Marc
I am almost 100% sure that my problem is in the config file where I point to the SQL server, butno values work at all, from inside or outside, I am publishing the data vis Microsoft ISA server 2004. Any help would be appreciated. Thanks - Marc
<-- Error
System.Data.SqlClient.SqlException: SQL Server does not exist or access denied.
at System.Data.SqlClient.ConnectionPool.GetConnection(Boolean& isInTransaction)
at System.Data.SqlClient.SqlConnectionPoolManager.GetPooledConnection(SqlConnectionString options, Boolean& isInTransaction)
System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()
Error -->
<-- web.config
<configuration>
<appSettings>
<add key="MM_CONNECTION_HANDLER_Lansweeper" value="sqlserver.htm" />
<add key="MM_CONNECTION_STRING_Lansweeper" value="data source=127.0.0.1;persist security info=True;initial catalog=Lansweeper;user id=lsuser;password=********" />
<add key="MM_CONNECTION_DATABASETYPE_Lansweeper" value="SQLServer" />
<add key="MM_CONNECTION_SCHEMA_Lansweeper" value="" />
<add key="MM_CONNECTION_CATALOG_Lansweeper" value="" />
</appSettings>
</configuration>
web.config -->
8 REPLIES 8
mmapplebeck
Hmm, I may have to work at this some more. I have just ordered 2 new servers anyways, may just rebuild new systems and start from scratch. Thanks for the help.
I also run in on windows 2003 without any problems
This thread had the same problem :
http://forum.lansweeper.com/Default.aspx?g=posts&t=28
mmapplebeck
I even used that, same problem. I amunning this on Windows Server System 2003, is there any security features that I should tweak to make this work? I know that 2003 has different security settings.
The problem is that you use a named instance of sql "ARTEMIS\CAH_SQL", so you have to use your named instance name and not "127.0.0.1"
127.0.0.1 would work if you only have a single instance of sql server running
mmapplebeck
<configuration>
<appSettings>
<add key="ConnectionString" value="data source=&quot;ARTEMIS\CAH_SQL&quot;;persist security info=True;initial catalog=Lansweeper;user id=lsuser;password=********" />
</appSettings>
</configuration>
The web.config has also had the ARTEMIS\CAH_SQL for the server as well and the quotes are properly used as "& q u o t ;"
Could you post your config file of the console application
mmapplebeck
That was the first think t\hat I checked. All is as it should. the server works fine using sql authentication so I know that works.
check your sql server security settings
Authentication : sql server and windows
yours is probably only windows
