02-27-2023 03:25 PM - last edited on 04-02-2024 10:25 AM by Mercedes_O
Hello LS community!
Not all our assets go from active to non-active. Is this because they are set manually to active?
We would like that all assets automaticity go from active to non-active is they are not seen in the last 45 days.
We are currently on v 10.3.1.0 and see attachment for the Cleanup options.
Kr,
Carlo
Solved! Go to Solution.
03-01-2023 09:39 AM
Hello there!
I would be happy to help!
Most of the confusion will probably be around what Lansweeper considers "not seen".
For example, if you have configured the "non-active" cleanup option to 45 days, the assets that have not been seen in the last 45 days will be set to "non-active", you can check the Scan Time tab of your assets to see if they have met this "not seen" criterium (see screenshot below).
With "not seen" we mean:
TLDR
All dates marked on the screenshot below need to be older than 45 days before the asset cleanup option will be triggered.
03-01-2023 09:17 AM
@Obi_1_Cinobi Can you help us with this question?
03-01-2023 09:39 AM
Hello there!
TLDR
03-01-2023 02:06 PM
Hello @Obi_1_Cinobi
Thank you very much for picking this up!
It is the ‘Last on-premises AD Domain scan’ that causes the confusion.
We are using the LsAgent client on our workspaces and have the ‘Active Directory Domain’ scanning target configured for the whole domain. I think this is double.
We only want to see computers active when they are used / on in the last 45 days. The 'Active Directory Domain' target scan checks if the computer is found in Active Directory?
Will it be better if I only enter the OU’s that do not contain computers in the 'Active Directory Domain' scan?
Greetings,
Carlo
03-01-2023 05:21 PM
Hello there!
The Active Directory Domain Scanning target will enumerate and query all available domain controllers to retrieve a list of computers and scans those computers. By default, this will indeed cover the entire domain.
So if your Lsagent-only computers are in distinct OUs, it would make sense not to scan these (for multiple reasons) and use an OU filter to weed out those assets from your agentless scanning targets.
This will result in the Last on-premises AD Domain date no longer being updated for these Lsagent-only computers, and if this date was preventing the cleanup option from kicking off, resolve your issue.
Don't worry about not getting any AD information for your LsAgent-only assets. While LsAgent in itself cannot perform an AD Lookup, an AD Lookup will be triggered after an LsAgent scan. For this to succeed, your scanning server does require a credential mapping to the correct AD domain with a credential that can read your AD.
02-28-2023 09:00 AM
I just updated the environment to version 10.4.1.0
