ericrsteele
Does anyone have a silent installer for Citrix Receiver 4.9 that works for sure? I have tried using this command "/EnableCEIP=false /EnableTracing=false /silent ALLOW_CLIENTHOSTEDAPPSURL=1 ENABLE_KERBEROS=Yes /ALLOW_BIDIRCONTENTREDIRECTION=1 /includeSSON /ENABLE_SSON=Yes /AutoUpdateCheck=manual /AURolloutPriority=Fast /AutoUpdateStream=Current ADDLOCAL=ReceiverInside,ICA_Client,SSON,USB,DesktopViewer,Flash,Webhelper" and it doesn't work. Thank you.
ericrsteele
@mikeNDF I apologize for the not responding, but I have not tried citrix GPO. I have no clue how to do it that way. Thank you.
Arjan
We use the following.
Step 1: Action 'Command' = tasklist | findstr /i /c:"cdviewer" --> This checks if cdviewer process is running on the targeted machine and will abort the installation if the Citrix receiver is currently in use
Step 2: Action: 'Installer' = "{PackageShare}\Installers\Citrix_Receiver\CitrixReceiver.exe" /silent /noreboot /AllowAddStore=N --> This will perform a silent install of the Citrix receiver.
mikeNDF
That looks complex, have you tried the citrix GPO to apply some of those settings?
All I use is the .exe:
"{PackageShare}\Installers\CitrixReceiver.exe" /noreboot /silent
