Lansweeper wrote:
Most likely the single disk is the problem.
Stop lansweeper service
Set the sql logging mode to "simple"
Shrink and reorganize the database
Stop sql services
defrag the harddisk
Well, I did what you ask me to do and:
- the function to permanently delete PC un lsmanage doesn't go yet;
Lansweeper wrote:
delete from tblcomputers where computername='mycomputer'
- PC's I had delete with script you give to me (I had try with 5 or 6 PC's), come back again.
My problem is that in my domain I have more than 500 PC that I can't have under my control ... now I have set them to "not active" but all data are in db and I need to delete them permanently: what can I do?
