thoughtmonkey
Has anyone been able to deploy LSAgent silently using SCCM? I've tried a few ways but doesn't seem to like the command switches. It installs the agent, but doesn't have the Auth key assigned and can't see the windows client in the Web Console under LsAgent scanning.
Any scripts to install via SCCM available or easiest way/method to deploy would be great.
David_Goodwin
Yes, Use the following command in your "Deployment Types / Scripts"
"LsAgent.exe" --server yourserverFQDNhere --port 9524 --agentkey agentkeyissuedtoserver --mode unattended
The -- double dashes are necessary. There is another post in the forum for deployment from the server itself and we have that working as well. https://www.lansweeper.com/forum/yaf_postst16524_LsAgent-for-Windows.aspx
