Sweeper
SMTP Emails are no longer working after upgrading from v11.3.0.5 to v11.4.0.4.
SMTP stopped working immediately after the upgrade.
I am now on the latest version v11.4.1.2 but still have the same issue.
When testing via the Web Interface, the test just keeps spinning.
When testing via the app: C:\Program Files (x86)\Lansweeper\Tools\MailTester.exe
I get this :
Connecting...
Connection Success!
Logging in...
Login Skipped!
Sending email
To: ****
Send Successful!
Any suggestions?
FrankSc
Dear all,
Could you please update to 11.4.1.4? There was an issue in previous versions, where certain jobs were not started. This is solved in 11.4.1.4.
Sweeper
Upgraded from v11.3.0.5 to v11.4.1.4 and email alerts appear to be working. Thank you @FrankSc for the update.
FrankSc
Dear all,
ring-rong
i have this problem too.
any fix? solution?
Sweeper
And going from v11.3.0.5, directly to v11.4.1.2 also breaks it.
So, the issue starts at least with v11.4.0.4.
I don't have any versions between v11.3.0.5 and v11.4.0.4 to test with.
Sweeper
Just to follow up, I restored Lansweeper to v11.3.0.5 from backup and SMTP emails are flowing again, so the issue is most likely in the v11.4.0.4 - v11.4.1.2 updates.
