taext
Hello Guys,
getting this error when I try to open the report for "not the latest build of win 10":
Error: Conversion failed when converting the varchar value 'Andoid' to data type int.
Website Version: 8.2.100.11
Server 8.2.100.11
Regards,
Dion
FrankSc
We'd suggest sending a mail to support@lansweeper.com to assist in troubleshooting this further.
taext
I've tried the report but unfortunately the andoid entry doesn't show up. Any ideas?
Regards,
dion
FrankSc
Since the report is converting the buildnumber to an INT-value, we assume that you will have a value 'Andoid' saved in tblassets for the buildnumber.
You can identify this by running a report with the query below. This should show you the affected asset.
select AssetID, AssetName, BuildNumber from tblAssets
