paprita
Imagine you have a big ICT infrastructure, deployed into different geographically separated sites and you want for each site, site administrators use Lansweeper without having the possibility to look at other sites data.
Imagine then there is a corporate administrator which needs to see all Lansweeper sites into a single view.
What's the best solution to solve this problem?
Doratheexplorer
Set the scanning IP Ranges for all Lansweeper-Servers to just scan "local" devices.
For this its needed to have all sites with their own (sub)net. Or is there a central DNS/DHCP-Server for alle sites?
Bruce_B
There's no direct functionality available for this but theoretically that could be possible. You can connect your Lansweeper databases to another database, we don't have a procedure available for this and can't provide support for it, but with queries and scripts a lot is possible.
paprita
By the way, what about if I create a procedure to gather information directly from DB istances to a central one?
Do you think this could work properly?
paprita
This is the answer I was expecting, unfortunately ... waiting for the new aggregation feature ...
Bruce_B
The first part, fully segregating assets, would require multiple databases and Lansweeper installations, one per site. For gathering all said data there currently is no functionality available yet, though we are working on a database aggregation tool in this context. We don't have an estimated release date for this yet though.
It is possible though to just scan all the sites in one installation for usage of the corporate administrator, though that won't have the benefit of directly originating from the "site databases" and would be completely separate.
