JustinL
I have a couple of questions regarding location maps.
Is there a way to "drag-select" or similar methods, to select a group of assets in order to move them around on the map?
In the location map, is there a way to hide/show different kinds of assets? For example, to only show computers or just show printers, etc
Thanks!
FrankSc
Hello Justin,
These would be good to have, but they are not available at the moment.
Can you submit a case to Lansweeper Support? They can create a feature request for it.
