pawnfodder
We are moving a database and will need to go to each pc and change the ODBC settings. Is there a way to use lansweeper to detect what ODBC connections are setup on workstations? We want to compile a list of computers that are setup with this database connection so we can then either change the settings via VNC / RDP or possibly use remote registry to make the changes.
Any thoughts / suggestions?
This key might help but you need a custom vbscript to read it out
HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI
pawnfodder
Thank you. I have noticed that key and will try to write a script to scan it, will post if i get it working.
