Hello all,
My Lansweeper scan replaces one computer with another.
I don't use an agent.
I have:
Server1 with ip: 192.168.1.10,
Server2 with ip: 192.168.1.20.
(server name and IP address are fictitious)
Server1 and Server2 is a virtual hyperv servers with Windows Server 2016.
I do a network scan in Lansweeper where I scan all assets from 192.168.1.1-192.168.1.254. The option "Saved Pinged IP" is active.
Target Server1 and Server2 are present in the "Scanning Queue" in "Windows computer scanning" Target .
After scanning i have only one asset Server1 with IP 192.168.1.20 (which belongs to Server2), or asset Server2 with IP 192.168.1.10 (which belongs to Server1). And i don't have the MAC address of Server1 or Server2 in the list of All Assets.
I tried removing assets and rescanned - same result.
Other servers are scanned fine.
The testconnection.exe logs for Server1 and Server2 are identical:
Lansweeper Connection Tester 7.1.0.1
Status: Running
Version: 10.3.2.0
Pinging Server1/Server2
Ping ok.
Scanning TCP ports..
135 open (EPMAP)
139 closed (NetBIOS Session Service)
445 open (SMB)
Checking DNS..
Server1/Server2 resolved to: 192.168.1.10/192.168.1.20
If this is not correct, please check for DNS problems.
Checking reverse DNS..
192.168.1.10/192.168.1.20:
Server1.domain.local/Server2.domain.local
Scanning netbios (UDP)..
Could not scan netbios
Scanning netbios (445)..
Scanning Active Directory..
operatingSystem: Windows Server 2016 Datacenter
operatingSystemVersion: 10.0 (14393)
Scanning WMI..
Computername: Server1/Server2
Operating system: Microsoft Windows Server 2016 Datacenter
Operating system: Windows Server 2016 Datacenter
Checking C$ Access
Deployment Folder: OK
Access Rights: OK
Checking Task Scheduler
Task was successfully scheduled
Task ran successfully
Task Deleted
Done.
With regards
Iurii
