ifm
screengrab.exe file version 4.0.0.55
When I try to use this new version of the screengrab, the installer hangs.
Two processes start (showing with psexec)
REMOTESCREEN.exe 3748 Console 0 3 148 K
REMOTESCREEN.exe 3540 Console 0 4 652 K
Nothing else happens and I get no screen shot.
Remote uninstall and Remote control works fine.
Any idea?
Schmoo
They've confirmed the problem and are working on a fix. I'm just happy to know it wasn't just me.
7 REPLIES 7
Schmoo
ifm
Usually I run screengrab from 64 bit win7 or Windows 2008 R2 server.
Cant see any blockage by anti virus, sometimes there is just nothing happening!
Can you contact us by e-mail for this problem (lansweeper@hemoco.com)
Schmoo
Might as well bump this. I reported back in April or May about problems with screengrab. I tracked the problem down to it either it not liking Server 2008 (tried on original 2008 and R2) or it not liking 64-bit OS's, or some combo of the two. Works like a charm on other OS's.
Basically you see it going through the normal process - installing service, etc., but when it gets to where it normally would pop up the .jpg, nothing happens.
ifm
I logged in with psexec and used tasklist to see what was running.
I have not successfully run any screen grab with the new version.
Tried on both XP and Win7.
Could you check if a virusscanner might block the remotescreen.exe
What do you mean with "showing with psexec"
Do you have this behaviour on all computers?
