‎10-08-2013 11:49 AM
i want to rename computers and to keep their history. I read Hostname Change/Duplicate MAC address and now know that i have to rename the computers name first in Lansweeper. More work than i want to do since in Asset ID is mentioned that there will be a mac-serial-based solution in 5.1.
When will this release be published? Will the old computername be stored in the new computers webpage for researches?
Best regards
Hannes
Solved! Go to Solution.
General Discussion
‎10-08-2013 06:57 PM
Rename detection can be enabled by ticking "Detect when a computer has been renamed" under Configuration/Scanning Setup/Server Options. Windows computers will then be identified based on a combination of model, serial number and MAC address. Note that Lansweeper will not keep a history of computer names. Only the most recent (current) computer name will be stored.
‎10-23-2013 11:42 AM
Best regards
Hannes
‎10-11-2013 04:06 PM
If you enable rename detection and rename a machine, the only change will be the name listed on the machine's existing Lansweeper webpage. All the rest remains the same. Note that the machine's new name will only be detected when the machine is rescanned.
‎10-11-2013 04:04 PM
‎10-11-2013 01:29 PM
‎10-11-2013 01:33 PM
jtseng01 wrote:
Hi, hardly to me to catch your statement. would very appreciatively if some screenshoot sharing here. or could mail me.thanks
Could you clarify your question? As stated previously: if you enable rename detection, Lansweeper will simply update the computer's existing Lansweeper webpage when you rescan. The computer name will be updated and all of the previously scanned data will remain intact.
‎10-11-2013 01:01 PM
‎10-11-2013 01:03 PM
jtseng01 wrote:
Hi, May I know what Lansweeper will do if Rename has been detected.(murge two asset into one? or ..? how many old data will move to new asset?) thanks
Lansweeper will simply update a computer's existing Lansweeper webpage with its new computer name. The existing page will continue to be updated upon rescanning. No "merging" takes place.
‎10-09-2013 03:28 PM
‎10-08-2013 08:45 PM
Are customfield indexed? Maybe i can type the old name into a custom field for researches.
Best regards
Hannes
