chogan201
Since upgrading to 12.3.2.3 this week, scanning has been an issue.
I currently have over 500 devices in the queue and it is increasing.  I have on prem devices that haven't been scanned since the update.  LSAgent devices are reporting in normally.
I tried clearing the queue, restarting the service, and restarted the server.
Anyone else having this problem?
Mister_Nobody
Honored Sweeper II
LS 12.3 has hidden firewall rules scanner.
Disable it via scan interval settings.
chogan201
An update as I look into this more.  Scanning is working, however much slower than before the update causing the queue to back up.
CPU and Memory on the server are within normal range and the web interface is responding normally.
I scaled back the scan intervals and will see if the queue eventually clears.
