Showing results forĀ
Did you mean:Ā
chogan201
Since upgrading to 12.3.2.3 this week, scanning has been an issue.
I currently have over 500 devices in the queue and it is increasing.  I have on prem devices that haven't been scanned since the update.  LSAgent devices are reporting in normally.
I tried clearing the queue, restarting the service, and restarted the server.
Anyone else having this problem?
2 ACCEPTED SOLUTIONS
Mister_Nobody
Honored Sweeper III
LS 12.3 has hidden firewall rules scanner.
Disable it via scan interval settings.
Obi_1_Cinobi
Hello there!
The performance issues with the firewall scanning scan item have been resolved in Lansweeper version 12.3.2.5:
  • LAN-17132 Improved Windows Firewall Scanning Performance.
You can update to the latest Lansweeper version by following the steps in this guide: https://www.lansweeper.com/knowledgebase/updating-your-installation/
If needed, you can always check our changelog to see all the additions, changes, and fixes that have been implemented in the Lansweeper software: https://www.lansweeper.com/changelog.aspx
10 REPLIES 10
Obi_1_Cinobi
Hello there!
chogan201
Support has registered the firewall rule scanning issue as a bug to fixed in a future release.  It is tracked as (LAN-17222).
Thank you Mr_Nobody!
chogan201
With firewall rule scanning really disabled, scheduled scans are running normally.
A manual scan (Rescan Asset from the asset page) still takes about 20 minutes, whereas prior to updating it was only a few minutes.
chogan201
Ok, so back to the Firewall rules scanning.
Checking again I found I didn't actually disable it when I thought I did before (not sure what happened).
Looking at the scan times on a PC, firewall rules is taking 37,538.42 seconds.  That's over 10 hours!  That would explain why the queue is backed up.
Now that firewall rule scanning is really disabled, I will see if we are back to normal.
chogan201
I'm going to open a support case.
Mister_Nobody
Honored Sweeper III
I disabled the firewall rules scanning.  I'll let the run today and see if it has any impact.
chogan201
I don't think that was it.  The queue shows it has been scanning the same 12 computers for the last 55 minutes.
Total scans counter has gone up 28 in that time.
chogan201
An update as I look into this more.  Scanning is working, however much slower than before the update causing the queue to back up.
CPU and Memory on the server are within normal range and the web interface is responding normally.
I scaled back the scan intervals and will see if the queue eventually clears.
