hlynch
I want to set a Target Scan for specific subnet
ex: 10.x.70.x are my printers
Is there a way to scan the subnet 70 for all my network ?
I dont want to scann 10.x.x.x totally because the scan never end this way.
ethanthekiwi
What you could do is use an Excel formula like ="10."&A1&".70.0" to create a list of all the subnets then use the import template in Lansweeper. I used Powershell to export all the scopes from our Windows DHCP server to a CSV, then removed all the scopes we didn't want to scan from the spreadsheet.
TheITGuy
You can manually create a subnet scanning by IP 10.1.70.1 - 10.5.70.254 All printer subnet
But if there are other devices that are configured for IP's within the ranges you have inbetween the printer subnets....well, see below:
You may need to create multiple scanning subnets instead of trying to do an all in one.
Like 10.1.70.2 - 10.1.70. 25 - printer subnet location 1.
Like 10.5.70.2 - 10.5.70. 25 - printer subnet location 2.
and since they are printers, they dont move so you can scan off hours.
WeatherDave
We do /24-/27 scanning, but I'd be leery to try much larger. Lansweeper handles those contiguous subnets just fine.
hlynch
Anyone else have Subnet allocated to specific devices ?
