harringg
I've added a ticket custom field that is a datetime record and has Agents Only and Required for closing checked.
I added a value when creating the ticket (self initiated as an agent) to the field. I then submitted the ticket, and closed the resulting ticket.
However, it required me to enter a value in the field when closing the ticket and overwrote the existing value.
I would have thought that since it already was populated, it won't require a new value.
Also, as a logged in agent, with the ticket assigned to me, I can't see that field in the closed ticket. I can see everything else.
Is there a setting to adjust so I can see the fields checked as "Agents Only" in the Change custom Fields interface?
Karel_DS
As an agent you should see the custom fields. This seems like the value isn't saved. Is this reproducible? If so please send the following to support@lansweeper.com:
  • link to the forum
  • screenshots of edit forms and the results
  • the following file: Program Files (x86)\Lansweeper\Website\App_Data\web_errolog.txt
