01-15-2014 10:58 PM
Solved! Go to Solution.
03-31-2014 09:21 AM
Lansweeper wrote:
We will not troubleshoot issues with serial number links, as these links will most likely be removed in a future update. They are obsolete, as Lansweeper should *scan* the warranty info. If you are having issues *scanning* warranty information, contact support@lansweeper.com and provide us with:
- Screenshots of the problem machine's Lansweeper webpage. Show us the following tabs: Summary, Scan Time, Errors (if it exists).
04-04-2014 01:09 PM
03-20-2014 11:07 AM
03-31-2014 09:21 AM
03-19-2014 12:31 PM
02-20-2014 09:55 AM
01-15-2014 11:09 PM
