blasto
Every day we have to hit refresh a thousand times and re-log in to get Lansweeper to function correctly. See the screenshot to see what it looks like. It happens every day.
We have reinstalled Lansweeper, run through the database cleanup checklist, but have not figured out why this happens.
Does this happen to anyone else?
klaus
Hi blasto,
We were having similar issues. First off the Lansweeper scanning service was dying frequently as there is an issue with warranty scanning. We are still waiting for a fix for this.
To mitigate the unscanned servers mostly, I have setup something like this:
  • Create a new deployment with the only action = Command, Name = Hello, Command = echo hello world, Success, Success
  • Tick the "Rescan Assets" box
  • Schedule this to run against the following report on a daily basis
tsysAssetTypes.AssetTypename,
tblAssets.IPAddress,
tblAssets.Lastseen,
tblAssets.Lasttried
From tblAssets
Where tblAssets.Lastseen < DateAdd(dd, -3, GetDate()) And tblAssetCustom.State =
1 And tblAssets.OScode Like '%s'
Order By tblAssets.Lastseen
For the slow dashboard, do the following. Wait until the alert widget loaded successfully. Then open one after the other report in a new window and take a note of those reports that take longer than a second to load.
Maybe you are as lucky as I was and find 1 or 2 that take about a minute to load. If that's the case, change the order of the where clause and see if it speeds up (< 1 second). If not, maybe exclude the report from the alert widget.
That worked for us and I hope it does for you
Try removing the Alert Report widget and see if that has any impact.
What is your database (SQL Compact or SQL Server) and web server setup (IIS Express or IIS) like?
Maybe this topic helps: https://www.lansweeper.com/forum/yaf_postst17188_LS-Dashboard-Reports-Broken.aspx
blasto
We're running SQL Server with IIS Express. Do we need full blown IIS? The database and server all look healthy. Has this never been an issue for you?
