‎03-01-2024
09:31 AM
- last edited on
‎03-06-2025
01:24 PM
by
Obi_1_Cinobi
I'm using Lansweeper v. 11.1.6.0, scanning a vSphere 8 environment. I have done all the steps in -->
Troubleshoot vCenter scanning issues - Lansweeper Community
However the Hosts and guests are not showing up in the vCenter inventory, only the Datacenter and the Datastores are visible.
What am I doing wrong? If I use the Lansweeper Devicetester I can see everything listed from the vCenter - it is just not showing up in the Web Interface
//Mathias
Solved! Go to Solution.
General Topics
Scanning
‎03-21-2024 07:29 AM
FYI, found the solution. Support pointed me in the right direction.
In my case there was a folder on the top of my vCenter inventory, above the vCenter itself. I removed that folder and now everything gets scanned as it should 🙂
‎12-31-2024 09:42 PM
when you say "there was a folder on the top of my vCenter inventory, above the vCenter itself", where did you see that at? Do you have a screenshot you can share?
‎08-19-2024 07:56 PM
What do you mean "on top of my vcenter inventory"? Can you post a screenshot or describe in more detail?
‎04-22-2024 10:39 PM
Greetings, I am having the same issue. Can you share more details about the workaround?
Regards
