‎01-25-2018
05:56 PM
- last edited on
‎04-02-2024
12:43 PM
by
Mercedes_O
I'm not sure if this is an open bug or limited to my installation. Trying to search for a name using the portion after a hyphen in the name does not return any results.
Example:
Computer name: ConfRm-Board
Search: board
No results are returned. If the search is
confrm-b
I get the above name in the list.
‎12-27-2022 07:01 PM - edited ‎12-27-2022 07:39 PM
%25 works as the wildcard search ex. %25G1234 or %251234 and also works for partial searches etc. That is what we do.
‎01-12-2023 07:50 PM
Thanks for that workaround. That helps quite a bit!
‎10-27-2022 10:16 PM
Me personally, I use a report of whatever criteria (all assets, all windows, whatever) and type what i'm looking for in the assetname column filter - hyphens work there (example: win10-vdi-01, or -vdi, etc). It may be two extra clicks, but it also returns whatever information you want it to - which I prefer over the limited asset info returned in a global search result page...
‎10-27-2022 05:45 PM
Lansweeper should address this. I use LS all day while working and waste much time typing the same 7 characters to finally have the machine I need visible in search. Frustrating.
‎08-16-2022 06:40 PM
Still an issue, really limits the ability to search.
‎08-17-2022 08:11 AM
Wildcards would help to keep it efficient, but they are not only not working, but showing potential SQL Injection vulnerability instead. I guess there is no other solution than feature request to Lansweeper, as it's certainly not a database limitation but search engine limitation (probably to help reduce the load).
‎01-26-2018 09:33 PM
